Core Electronics Forum
Polymer Lithium Ion Battery (LiPo) 3.7V 4400mAh (CE04380)
This is a placeholder topic for “Polymer Lithium Ion Battery (LiPo) 3.7V 4400mAh” comments.
This Lithium Polymer Ion based battery is a slim, lightweight battery that is perfect for a portable project! LIPO chemistry is the highest energy density chemistry around and due to that, you get nominal 3.7V at 4400mAh!
Is the CE04380 battery the same size or smaller than the ADA354 that it replaced. We have instrument kits which were designed for the ADA354 and we require additional batteries. We can’t modify the instrument housings to accommodate anything larger.
The “Read more” link takes you to the product description which states
CE04380 Dimensions:
52x34x24mm
ADA354 Dimensions:
69mm x 37mm x 18mm / 2.7" x 1.5" x 0.71"
