Hi all
this is my first post in the forum
we need to program PIC12C508-04/SM
this needs Picstart plus
We bought MPLAB COMPATIBLE USB PIC PROGRAMMER
is there any setting / mechanism to emulate Pickstart Plus
please help
Hi all
please help
Hi Param,
Seems PICStart is getting a bit long in the tooth, any reason why you’re restricted to that particular chip ? (looks like you might be repairing/troubleshooting an old device?)
https://www.eevblog.com/forum/vintage-computing/before-pickit-there-was-picstart/
The programmer you purchased is only compatible with PicKIT 2 and MPLAB according to the product page:
Years ago I bought a K150 clone programmer to program PIC16F628A. The program to do the programming is microbrn.exe. I just started microbrn and 12C508 is in the list of chips it programs, with a picture of where to put the 12C508 in the ZIF socket. Don’t know if that’s useful.
You might like to investigate the PIC12F1501. It looks to be pin compatible with the 12C508 but easier to program, and is a flash device so can be reprogrammed if necessary. The F1501 instruction set is similar to the C508, but not exactly the same. The C508 has a TRIS instruction which has been dropped from recent PICs, the TRIS register is just another memory location. It depends on why you want the 12C508.
HI All
many thanks for your comments
it sems that the only programmer which can program PIC12C508-04/SM is pic strat plus
will attempt and will advise
