Project by David55659; PiicoDev Ecosystem In Fritzing
I have just shared a new project: “PiicoDev Ecosystem In Fritzing”
This project began with a desire to make circuit building readily approachable for students new to electronics by bridging the gap between schematic diagrams and working circuits. The PiicoDev ecosystem provides a very accessible introduction to ele…
Incredible work @David55659! Very tempting to use these in a video when we next need some diagrams, will give you a shout out!
Thank you David.
That is genuinely such a fantastic project.
All of the kudos to you.
No matter how much you proofread, it seems there is always something that gets overlooked. In the second example code in the “Hardware setup” section of code, I have assigned one of the colour sensors to Pin 2 and Pin 3, but the wiring diagram shows the sensor attached to Pin 26 and Pin 27. The code should read:
# ---Hardware setup---
display = create_PiicoDev_SSD1306()
sensors = [
    PiicoDev_VEML6040(bus=1, sda=Pin(26), scl=Pin(27), freq=400000),
    PiicoDev_VEML6040(bus=0, sda=Pin(8), scl=Pin(9), freq=400000),
Thank you for creating these parts! I feel that the Fritzing app has tremendous potential, although I think it’s a bit clunky on how you have to add parts one by one. To be fair I haven’t used it much to get a proper working knowledge. My goal is to use Fritzing to keep a visual record of circuits I make and store them along side the MicroPython code I write for future record etc. Hopefully I may get some time in the future and make the Glowbit and Mkrvrs parts to join them. Keep up the excellent work.
@Laurence257160 that would be great if you were to add more Core Electronics parts. Which parts are you considering? There are a few Mkrvrs parts that have been on my “to do” list (2 channel motor driver and IR analog line sensor) but haven’t gotten to yet. No point in duplicating effort.
I think the Glow Bit range would be a good start as it’s simple looking (on first look). But as I’m time poor, I can’t commit to anything just yet, but I will familiarise myself more with Fritzing and investigate part creation further on.
