I am looking for parts suggestions to create the following project -
AIM to have a remote outdoor FIXED GNSS BASE unit (EMLID -LiFePO4 3.2V, 30.72 Wh battery accessible and communicatable via wireless from a Raspberry pi node which in turn is connected to the things network.
Pi to be within 1m of GNSS unit.
I’ll also need to create a things gateway as nothing local – housed in building with external aerial – has 240v available. 50m from GNSS base station.
GNSS unit requires power input between 5 & 40 volts.
What I’m thinking is the following modules
- Solar Power with 12V storage. Charging regulation and Protection
- Raspberry Pi as a node with UPS
- Things Gateway (NO Gateway within the area) - Laird Sentrius RG191 LoRaWAN Gateway (AU Version)
- The above pi Node with Communications to Things Gateway and GNSS Unit
Any additional modules or suggestions?
DETAIL Components, sizing and Parts SUGGESTIONS
- Solar Power
Fixed Solar Panel, sizing, type etc cables, Intelligent monitoring for battery condition and charging/discharge parameters. loss of input power etc
12V low maintenance Battery
- Node with UPS
Raspberry Pi 4 mod B 8GB
piJuice + 10000mah battery??
System cooling??
Power step down, regulation and monitoring from 12V Battery
- Gateway
External Aerial
Cabling and connectors
- Communications
- Something like PyCom modules - require Wireless, Bluetooth, GSM
- Power to the module
The installation is outside in the weather so a fixed permanent solar panel is preferred over the folding transportable variety. Follow the sun isn’t really required.
Discussion and Any advice appreciated.
