Push button switches
Could you please advise if you can have help with the below?
We have an application for a flush momentary push-button switch that needs to be 15.8mm in diameter thread. The button needs to also be flush on the top. If so what length do you have available and would you have LED and non LED versions available?
Also I am also looking for a separate application, 3x push button protruding with LED with the same dimensions as above.
Could you advise if you have anything that would match both applications?
Welcome to the forum Sandy!!
Unfortunately we dont have any fully flush buttons directly in the range, mounting them on a fixture plate just below the surface could work!
I’d check out these metal pushbuttons: https://core-electronics.com.au/catalogsearch/result/?q=button+16mm
Otherwise quite a bit of customisation might be necessary!
Let us know how you go and if you have any more questions feel free to pop them up!
