Hey Guys,
I have a very specific switch that uses two micro SMB momentary switches connected to a PSB board, however the two switches share a common wire.
I need each switch to have its own two wires. Therefore I am looking to build my own.
I have no electronic knowledge but know it should be possible either as a hack (Soldering wires to the ends of the SMB buttons) or properly making my own PCB.
I am trying to do this on the Cheap $20 or less.
The board that the 2 switches sit on is 25mm long x 8mm wide.
The Switches are as follows:
The 4 wires need to be at one end of the board.
I would love to know how you would approach this project.
I was thinking possibly making my own etched PSB board. The biggest issue I face there would be how do I mount the switch on the board, are they soldered onto the copper. Also drilling 4 small holes in the end of the board.
Could I use perfboard.
What would be the simplest way for me to complete this.
Please think novice/very small board/switches etc
