If you’ve ever made a mistake when surface-mount soldering, you’ll know how much of a pain it can be to fix it without the right tools. It can add critical time … read more
We discontinued the Quick 861DW Hot Air Soldering Rework Station because our supplier chose to remove it from their range, so in this case, it was just upstream supply issues that meant we moved away from that model.
