If you’ve ever made a mistake when surface-mount soldering, you know how much of a pain it can be to fix it without the right tools. It can add critical time to…
Hi James.
Thanks for that. I thought they may have fitted onto my gas tool as they looked a lot smaller in the pics. However when I did what I should have done in the first place and measured approximately on the computer screen and scaled it to the known dimension (the output hole) I can see the larger size and would not have asked the question.
Regarding the smaller sizes. I have made a couple of comments about using nozzles smaller that what is provided with heat guns here
and I think this would apply here. Probably OK if heat turned down in proportion as if you used one of the smaller bits and got a bit ambitious with the heat setting the nozzle would glow a bright cherry red until the heating element expired.
I have seen this happen on a quite regular basis even with very well made and reputable (Raychem) expensive hot air guns.
A note of caution in the description text might not go astray.
