Heat shrink is the duct tape of electronics which I guess makes this heat shrink the colorful and exciting duct tape they sell at craft stores. This heat shrink…
Good to know. Maybe something if I start to need to heatshrink often.
Isn’t that when you make your custom boards? Like this? I’ve seen concept in KiCad but I have no idea what to do with it yet. Good to have the advanced warning that PCBs are in my future somewhere.
Hi Pix
If it were hot enough it would be quite dangerous as a hair dryer. In fact most quality hot air guns have a notice on them specifically saying NOT to use it as a hair dryer.
So the short answer, Not recommended.
I have a hot air gun which will happily melt solder, like max 600ºC. Never use it at that extreme. A small word of advice if using such a tool. Never use a nozzle smaller that that which is supplied with the tool. I have experienced it a few times where the nozzle size had been reduced in an attempt at a more localised air flow with the result of a burnt out element due to over restricted air flow over it.
I also have a “Portalsol” gas tool which I use pretty exclusively for small heat shrink. This has a hot air tip that will provide a quite small localised hot air stream. It is in the Jaycar catalog as TS1318. Fairly expensive but a good investment if wishing to have a more professional finish instead of burning everything in sight. It is quite convenient in operation even on a turn on/turn off basis as it is easy to ignite and heats very quickly.
