I am looking at creating a pin release mechanism powered by a solenoid. I want this to be controlled by a wirelss remote though a random timer. To expalin, I would press a wireless controll button that will initialise a random timer switch to activate the solenoid once at a random interval within 5-15s. We are considering using a lock type and or push pull type solenoid. Would anyone be able to help in regards to the circuitry regarding how to complete the timer system and remote.
That’d be pretty simple to do with a microcontroller, have a read of our guide on controlling solenoids with an Arduino (the process should be pretty similar no matter what microcontroller you’re using):
As for wireless functionality, something like this would likely be the simplest:
Alternatively, a bluetooth-based system might also work well, but would require a good deal more coding.
The time delay coding would be super simple, something like delay(random(5000, 15000))
Let us know if you have any more questions!
G’Day James, thanks for your reply. I would like some more information regarding the products I need to complete the circuit so I can order them all in one go. Do I need products like the Arduino Uno, power transistors, diodes and so on, if so can you please list them. And the products like the microcontroller and the coding platform, does it matter which one? I’m an amateur at doing projects like this so can you please give me an insight on which things to buy
Yeah it should be good, I remember Bob mentioning battery banks like this having a threshold current where it remains on but the ESP32’s are a bit more power hungry than say a Pico or Arduino. It’d be great to get some measurements though.
Also if you are worried you can also go for a LiPo pouch and connect it to the JST port on the side, just make sure you have the same polarity that Adafruit intended (you’ll need a multimeter).
G’Day Liam, could you help me out in regards to the remote wireless link kit, the one suggested above is not in stock and I need to get my hands on one asap, is there any alternatives that will work with my system? if so can you please list it.
