Raspberry Pi 3a error using external rotary encoder with VideoLooper
Hi all,
Im currently working on a project to automatically play video using video looper on a Raspberry Pi 3a with an external audio rotary encoder (ec11) module.
I found a script that adjusts the volume using the encoder which works when run manually from the desktop. But i want it to work when video looper starts. Basically if someone wanted to adjust the volume while video looper was playing they could just use the rotary encoder.
I’ve added a boot script to the conf.d folder (/etc/supervisor/conf.d) which mentioned the python3 script to start the encoder script (same one i used manually in desktop mode). But each time i start the PI, video looper runs find but i cant get the encoder to work.
Checking the log file i can see that this error keeps appearing "ModuleNotFoundError: No module named ‘alsaaudio’
Does anyone have any ideas on how to resolve this issue?
Hi @Scott253186, Welcome to the forums!!!
Could you provide the script you are using as well as how you have the rotary encoder module hooked up?
I have a suspicion there may be something that happens during boot that isn’t happening before your script runs causing it to not detect the module.
Thanks for your response. Yeah im thinking the same thing.
The script im using is shown below. I didn’t create it but i did modify it a bit to suit my needs.
The rotary encoder im using is the DFROBOT EC11 Rotary Encoder.
Code for Controlling Pi Volume Using Rotary Encoder
Original Code: https://bit.ly/2OcaQGq
Re-Written by Sid for Sid’s E Classroom
https://www.youtube.com/c/SidsEClassroom
All text above must be included in any redistribution.
If you find this useful and want to make a donation → PayPal.Me
from RPi import GPIO
from time import sleep
import alsaaudio
Change the following pins based on your application or HAT in use
encoder_clk = 4
encoder_data = 17
encoder_button = 27
GPIO.setmode(GPIO.BCM)
GPIO.setup(encoder_clk, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(encoder_data, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(encoder_button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
m = alsaaudio.Mixer(‘PulseAudio’)
m = alsaaudio.Mixer(‘Master’,0)
for mixername in alsaaudio.mixers():
if str(mixername) == “Master” or str(mixername) == “PCM”:
m = alsaaudio.Mixer(mixername)
Set desired minimum and maximum values
min = 0
max = 100
Set the volume change step size
volume_step_size=5
is_Muted = m.getmute()[0]
volume = m.getvolume()[0]
if is_Muted == 0:
is_Muted=False
else:
is_Muted=True
print(“Mute State: " + str(is_Muted))
print(“Volume: " + str(volume))
print(””)
clkLastState = GPIO.input(encoder_clk)
btnLastState = GPIO.input(encoder_button)
try:
while True:
btnPushed = GPIO.input(encoder_button)
if ((not btnLastState) and btnPushed):
if is_Muted:
is_Muted = False
m.setmute(0)
print(“Volume: " + str(int(volume)))
print(””)
else:
is_Muted = True
m.setmute(1)
print(””)
sleep(0.05)
else:
clkState = GPIO.input(encoder_clk)
dtState = GPIO.input(encoder_data)
if clkState != clkLastState:
if dtState != clkState:
volume += volume_step_size/2
if volume > max:
volume = max
else:
volume -= volume_step_size/2
if volume < min:
volume = min
if clkState == 1:
print(””)
m.setvolume(int(volume))
clkLastState = clkState
btnLastState = btnPushed
finally:
GPIO.cleanup()
Hey @Scott253186
Quick sanity check: is alsaaudio installed?
#assuming you installed with pip
pip list | grep alsaaudio
Hi @Pixmusix
yes, it is. pyalsaaudion 0.8.4 installed.
@Scott253186 you might find that it is more appropriate to run your script at boot by setting up a cron job instead.
I’m not exactly sure what the behaviour of running scripts at startup from /etc/supervisor/conf.d is, but using cron seems to be safest in general - especially when it seems you’re executing the same command but a module is not found.
The good news is it should be easy enough to try:
edit the cron table with
crontab -e
and append a line to run your script at reboot
@reboot python3 /[path to my script]/my_script.py &
& will run the script in the background.
(of course, remove your existing conf.d implementation first.)
