Hi All,
Using Noobs and a TV but struggling with HDMI audio out. Using stock Raspberry Pi power & HDMI cable from Core-Electronics The GUI shows HDMI in use (right click volume top right).
Raspberry Pi doco suggests the GUI, command line and raspi-config, tried all three. I even tried /boot/config.txt without success.
Tried two TVs, and my monitor (via audio out jack on the monitor). Analog sound is fine.
Only software installed is Kodi (not running) and barrier (running). All software up-to-date.
Ok so there are two HDMI ports only one supports audio. I swapped to the other port and all good.
Incidentally, Kodi had is own setting for audio independent of the underlying OS. That setting also permitted HDMI and analogue which is exactly what I wanted for Pi as a media centre.
