Raspberry Pi 4 Model B 4GB [PREORDER] (CE06425)
This is a placeholder topic for “Raspberry Pi 4 Model B 4GB” comments.
The 4GB variant of the Raspberry Pi 4 Model B
Will the Raspberry Pi 4 B 4 GB come any sooner
Hi George,
Thanks for checking in. They might, in fact we’ve had some boards arrive just recently. Though they are shipping on a first-ordered first-shipped basis.
We’re quoting into the future for safety, as we are setting realistic expectations for what is a very-in-demand product. We’re getting boards straight off the production line via the mothership, eventually they’ll get back in front just as the days of Pi Zero :slight_smile:
Graham,
I’ve been looking at the Pimoroni case and fan, do you expect to have them available, or make something similar?
Dave
Hi Dave,
We sure do. Here’s a link (more Fan SHIMs are arriving this week, and more again next week).
Other colour variations of the Coupé are available as well.
I want them all to upgrade the ‘Desktop PC’, but the $35 computer adds up to about $150 when you go 4M, case, fan, power supply, micro HDMI lead.
And thinking USB SSD too!
Better get the Tax return Cheque :slight_smile:
Dave
Hi , Is it possible to add co-axial / optical output to Raspberry Pi4 ?
if yes, what will be the additional cost ?
The RPI4 won’t likely change features for a long while. HDMI has passthrough digital audio which suits most popular use cases.
There’s also a 3.5mm TRRS socket onboard (and we have this cable to suit), which provides composite outputs.
Some light Googling landed me on third party products that might be useful, though without having used them on RPI4, it is hard to recommend something.
Would a Pi 4 as a media server support two other Pi’s running Kodi? With Pi 4 cabled to router and the two KODI’s on wifi…
Is this stock revision 1.2 which fixed the USB-C charging problems, please?
Rasbarry Pi 4 Model B Bored And Thar Revision
  • Raspberry Pi 4 Model B [2GB] boards are a mix of Rev1.1 and Rev1.2
  • Raspberry Pi 4 Model B [4GB] boards are Rev1.2 (latest hardware revision) Witch Has The Usb-c Fixed
wow
I am unable to purchase the raspberry pi 4 model b 4GB DIY Kit, even though I have 4 additional accessories in my cart.
Hi Andrew,
Welcome to the forum!!
To checkout with a Pi 4-DIY kit 3 of the accessories must be greater than $10 each and within the ‘Raspberry Pi’ category.
Some examples include:
These are just some of the accessories that most makers need to get started though there are a ton of other ones in the category!
customer since 2017 - can I sign up for Pi4 4Gb waitlist?
what chipset is the Raspberry Pi 4 Model B 4GB …32bit or 64bit?
Hi @Johannes143862,
It’s a 64-bit CPU, however, the 32-bit Raspberry Pi OS works best as it has had more time in the sun with RPi developers.
Any ETA on the raspberry pi compute module 4s yet?
My Pi400 is causing me grief with the HDMI connection failing if my keyboard moves and often disconnecting or failing to connect to the display. What solutions can you throw my way please
Hey there, @John198007,
Might be worthwhile first confirming whether the issue is the micro-HDMI ports or the cables. Are you seeing same effect when using other HDMI cables? If you are, it might be worthwhile inspecting the HDMI ports for any sign of damage.
