Could I check if this riser: https://core-electronics.com.au/2x20-socket-riser-header-for-raspberry-pi-hats-and-bonnets.html will physically fit the GPIO open area in RP Zero slim case: https://core-electronics.com.au/slim-case-for-raspberry-pi-zero.html to raise the GPIO pin higher. I am thinking of putting PImoroni Enviro+ https://core-electronics.com.au/pimoroni-enviro-air-quality-for-raspberry-pi.html after I am done with my project.
Also would you someone be kindly enough to quickly measure tell me how high the Pimoroni Enviro+ becomes after using the riser so I can get the closest longer screw to hold the Enviro board.
Oh well, I don’t like the Pi Zero (or other system or Pis) nakedly attached to the Enviro HAT (or other HATs), if one would ask why.
Thank you.
Regards,
Iman
