This is a placeholder topic for “Rugged Metal On/Off Switch with Green LED Ring - 16mm Green On/Off” comments.
These chrome-plated metal buttons are rugged and look real good while doing it! Simply drill a 16mm hole into any material up to 1/2" thick and you can fit these … read more
Want to get the 470 ohn for the green ring led switches and wiring and fuses. Need help though
Hi Glen,
Welcome to the forum!!
The LED resistor will depend on the voltage that you have across your switch, I’d check out our guide on Ohm’s law and grab a resistor pack, we love this one: Resistor Kit - 1/4W (500 total) | Sparkfun COM-10969 | Core Electronics Australia
As for wiring and fuses what were you looking to connect the switch up to? Note that the max rating of the switch is:
- Switch rating: 3A / 250VDC
