SD Card Module SKU: CE05113
gday. for chip select - which pin to use for the UNO?
thanks
on the SD module with its double pins
are these duplicates or are only the inner pins connected?
thanks
Hi Joe,
The normal chip select pin on the Arduino Uno is pin 10.
On the SD card module CE05113 the pins are duplicates (common).
