I am attempting to seal a 1cm diameter hose to the 12V solenoid valve from core electronics link: https://core-electronics.com.au/plastic-water-solenoid-valve-12v-1-2-nominal.html
The setup is shown below:
To ensure no water leakage i would like to use a strong sealant (link: https://www.bunnings.com.au/selleys-80g-all-clear-multipurpose-sealant_p1230113) however; it says on the package that the sealant might damage poly carbonate and polystyrene. Will this be an issue of concern for the plastic valve as I am not aware of what material it is made from.
Thank you very much.
