An artist friend wants to make a work that emits sound when certain triggers are fired. Eg: a proximity switch or maybe a pressure pad. So, an mp3 player with a micro SD slot, connected to some switch inputs is what I think she needs. I have bought something like this in the past but can’t remember what it was called.
Hi Greg,
I’m going to go out on a limb and say that it’s probably the Adafruit sound boards that we offer. There’s quite a few variants depending on how much sound you need to store, whether it needs to fit somewhere small, and whether you need an amp in-built
Have a look and get back to me if you need some more help!
Thanks James,
I’m talking to the artist about space constraints etc. Apparently it is a box with a seascape inside. She wants it to play sea sounds when the box is opened.
Greg
Hi Greg,
To follow-up on James’s response, they also go under the name of a WAV or MP3 trigger.
To get the audio triggers working with different types of sensors you will most likely need a microcontroller to act as a middle man.
Some sensors also have thresholds that you can use to send an activating signal to the sound-board!
Core also has these cool boards here that could work.
I’m keen to see how your project comes out!
Liam.
