This Sensor/Motor Drive Board (Cortex M3 CPU) is the integration of multiple communication interfaces that quickly build robotic systems. This board (Cortex M3 CPU) features the SPI Interface and works as a bridge between the whole system.
Is this board reprogrammable by the user or is it only controller that must be a slave to master board e.g. PLC/ Arduino? Do you have more detailed documentation about this board: how to code software for it, how to connect for programming etc?
Thank you for the answer. I am going to use this board for PID control of the motor. In order to properly setup PID, i need to know what algorithm is used in the firmware. Can you please tell me what algorithm for PID this controller has: Ideal (also called “ISA”), Series (also called “interacting” or “analog” or “classical”) or Parallel (also called “non-interacting”, “independent” and “gain independent”)?
