This is a placeholder topic for “smôl 100mm 16-way Flexible Printed Circuit” comments.
This is the 100mm 16-way 0.5mm-pitch Flexible Printed Circuit used to interconnect smôl boards end to end.
_smôl is an ecosystem of miniatu…
Read moreThis is a placeholder topic for “smôl 100mm 16-way Flexible Printed Circuit” comments.
Read moreHi, does this work with the Raspberry Pi 5 PCIe port?
Hi @Stephen106330, Welcome to the Forums!!!
From what I can see this FPC does have the same specs as the Pi 5 PCIe connector so it would technically fit:
16 Pins, 0.5mm pitch
However, this document that outlines the Pi 5 PCIe connector standard says the FFC must be of the opposite-sides-contact as well as the recommended length is shorter than 50mm.
Using this FPC would not comply with the standard.
