Snap-Action Switch with 16.7mm Lever: 3-Pin, SPDT, 5A (POLOLU-1402)
This is a placeholder topic for “Snap-Action Switch with 16.7mm Lever: 3-Pin, SPDT, 5A” comments.
This single-pole, double-throw (SPDT) momentary switch can be used as a general-purpose micro switch or tactile bump sensor for your robot. The switch body dimension is 20.0 x 6.4 x 10.2 mm, and the lever arm is 16.7 mm long.
How waterproof is this? If it is not what would be a good alternative?
Ideally IP69 if not IP68 (5m Submersion in Salt/Chlorinated Water)
Hi James,
I have a feeling this one isn’t IP rated with anything that would let it get close to water.
The only thing I can think of getting to IP69 would be a reed switch full enclosed (with your other electronics) and a magnet on a spring outside the enclosure
Yes that makes sense. I am intending to directly supply a small motor and some solenoids off this switch.
This guy: Magnetic Switch | Buy in Australia | SEN0387 | DFRobot | Core Electronics Looks like it could handle the water, however I am not encouraged by its current rating, which appears to be only 50mA, compared to the bare reed switch’s rating of 1.2A.
Would the core mag switch work or should I look elsewere for something?
Hi James,
You could look at using that switch to trigger a relay or mosfet to get around the limited current capacity that the switch has.
