I’m trying to make a prototype star tracker and hooked together the following stepper and controller. But the motor doesn’t spin, it just chatters and rattles. The motor is a Nema 17 2 phase four wire 0.4A 12V. The controller a generic board. I’ve double checked the wiring and can find no fault. Has anyone any idea what might be wrong?
Hey, @Richard51573. Thanks for bringing your question to the forum.
Here are all the questions I can think to ask at the moment
Are you supplying 12-24V at the correct motor power supply inputs?
Under the circumstances you’ve described, does the motor have any holding-torque? Are you able to turn the shaft by hand when everything is powered?
Are you controlling by the manual control-keys or a pot?
What are the status LEDs doing?
What happens when you connect a potentiometer to the relevant input?
Try running a simple DC motor on channel A then again on channel B. What do you observe?
Does your stepper motor work? Try manually energising the coils in sequence to get it to rotate some continuous arc.
Would you mind uploading a photo of your own setup? I know it’s a simple arrangement, but a picture can be really helpful.
Thanks for the reply Michael. I eventually found the problem, the motor has
a six pin plug. Coil A uses pins one and four. Coil B uses pins three and
six. I had expected 1&3, 4&6.
Regards,
Richard.
Isn’t that just the way of things! Glad you found it in the end
Always check the obvious first
Serves me right for buying ‘too cheap’ from china - no wiring diagram and hard to find anything to help on the www.
This project is s prototype for a star tracker for my camera. If it shows promise I will make a much more precise tracker with quality products from Core Electronics. If anyone on the forum has a reliable way to locate the South Celestial Pole please share your knowledge. I am hoping a template with the Southern Cross together with the two pointers can be used in a similar manner to the simple bomb sight used by the Dam Busters will do a reasonable job.
Richard.
