SSR-60DA Solid State Relay (CE05351)
This is a placeholder topic for “SSR-60DA Solid State Relay” comments.
A solid state relay (SSR) allows you to control high-current AC loads from lower voltage DC control circuitry…
Hi, im looking for a 0-10vdc input ssr with zero crossing switching and phase angle load control
HiMichael
I am assuming you mean control voltage. This unit has a control voltage of 3 - 32V
Most SSRs are zero crossing which means AC only (as DC does not get to ground so never switches). “Switch any time” devices are available but not common.
If by that you mean power factor the relay has no control over that. Entirely up to the load characteristics.
