This switched JST connector is the best way to quickly prototype with Adafruit’s LiPoly batteries. Adafruit paired a genuine JST connector with a slide switch that can do up…
Hi Core people;
I am looking for a device similar to the ADAFRUIT Product 1863, but that has solder connections and no 2 Pin JST connector. The intent is that this will be used as an external power switch on an enclosure for a GPS Datalogger. I want to be able to turn off the battery power reliably using a switch like this that would be mounted on the outside of the data logger enclosure.
Thanks, Peter.
