A LoRa expansion board for Raspberry Pi offers ultra-long-range wireless communication up to 5 km, wake-on-radio and UART control for DIY IoT applications.
I will let core respond for themselves; as i dont work for them.
I would be amazed if the module would not work with meshtastic and other lora projects. the SX126x series is very very common and that radio is supported on many different controller boards (not sure about the pi directly).
If you consider lora is a radio coms protocol. people then build ontop of that for projects like mesh networks and loraWAN (of IOT) to central servers.
Modules are normally built and sold for end users to have options to build projects, its kinda up to the end user to work out what bits will work the way they want them to.
e.g. I would be 99% Sure I could make the module work on an ESP32 and tweak and compile a meshtastic firmware and make it work. But not everyone wants to spend time doing that, sometimes people just want to plug and play and have it work. The more you want to plug and play the more you need to confirm it will work that way.
While they dont say it wont work, they also dont state that it will.
Edit:
While Im not a big pi user, and there may be some work here. Given how common this lora chip is, Im sure with some work, it will work.
