This is a placeholder topic for “Timing Pulley - Shaft Mount (16T; 6mm Bore)” comments.
These shaft-mountable aluminum timing pulleys use XL timing belts and attach to a 6mm output shaft with a set screw. They have 16 teeth with a gear pitch of 1/5P, an outer diameter of 1”, a bore of 6mm, and requires a belt width of 3/8”.
