I recently purchased a dfrobot beginner arduino kit to work on for school. Today i decided to test out the arduino uno but i couldnt get it to upload. im not sure if its a defect or the code. But i get an error message when i try to upload the code. Theres no problems with verifying. Its a very basic code. Also when i click the reset button, nothing happens. I read somewhere that LED on pin13 should flash a couple of times after reset.
Heres the code below
int LEDPin = 13;
int waitTime = 500;
void setup() {
pinMode(LEDPin, OUTPUT);
void loop() {
digitalWrite(LEDPin, HIGH);
delay(waitTime);
digitalWrite(LEDPin, LOW);
delay(waitTime);
and this is the result i get
Sketch uses 946 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\Tommy\AppData\Local\Temp\arduino_build_964923/blinking.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf7
avrdude done. Thank you.
During school times, ive used the same arduino uno module on my computer so i know it works on my computer but due to online study i had to buy the kit.
I have already tried uninstalling IDE, restarting my computer, disconnecting and reconnecting arduino uno.
Please help.
