This is a placeholder topic for “USB 2.0 and Ethernet Hub - 3 USB Ports and 1 Ethernet” comments.
One can never have enough socks, or USB ports. Add some more USB and Ethernet capability to your Raspberry Pi or, really, any kind of computer with this USB 2.0 … read more
              do you need to install a driver/library for this ? (e.g. apt-get etc)
              Hi Ray,
There should be no drivers needed for this.
              When I plug this ethernet hub into my windows 10 PC its not recognised.  Is there a windows driver for it?
              The device appears to be in the Microsoft Windows Driver Catalog, so choosing the search on-line option at installation time should find the correct driver for this device.
If that doesn’t work you can look for the device in Device Manager.  You should then have a Hardware ID (under Details) that you can search on. If you are unfamiliar with installing Windows device drivers please note that you should never download an EXE file for a device driver installation - it will almost always contain malware.
If you can’t find a match by Hardware ID try this one:
Download ASIX AX88772A USB to Ethernet Driver 3.18.2.0 for Windows 10 64 bit (softpedia.com)
              The Microsoft Update Catalog lists Windows 10 drivers dated 2016.
You could try these.
I have the micro usb version of this hub working on a Pi Zero to give the Pi a Ethernet port.
Have not tried it on a Windows 10 PC.
