Viewing a CCTV recorder feed through network
Trying to view a Hikvision recorder live view through LAN. Have tried fullpageOS and i can access the recorder but plugins are needed to view the feed which im not sure how to do. Also tried installing Emteria OS but it reboots every 8 hours which i cant have. Ideally i would like to use an android operating system so i can just download the IVMS app and set it to boot on start up incase of power outages ect.
Thanks in advance,
Sam.
Hey Sam,
Welcome to the forums!
If you need an Android OS then LineageOS is the best option for it. As for it starting on boot, I am sure there is the availability to get that done, it would just take a bit of research as to how that would function.
Try and get the process started with LineageOS and I will get back to you with a bit of info on how Start-up on boot applications run on that particular OS, though, someone with a bit more experience with that operating system may jump in before I do!
Blayden
