Waveshare 4G HAT for Raspberry Pi (LTE Cat-4/4G/3G/2G/GNSS) (CE07826)
This is a placeholder topic for "Waveshare 4G HAT for Raspberry Pi (LTE Cat-4/4G/3G/2G/GNSS) " comments.
Enable LTE Cat-4 4G/3G/2G communication and GNSS Positioning for your Raspberry Pi
Can you use the waveshare 4g hat with a raspberry pi 3 model A+
Welcome Mick!
You definitely can - this HAT uses the same 40-pin Raspberry Pi header that all modern Pi’s do.
I’d love to try this. Before, I only used SIM900A to make this kind of projects: Sending SMS & Call with GSM Module and Raspberry Pi 4 - The Engineering Projects
But SIM900A is not 4G supported. Good to see that we have 4G enabled HATs now.
Hi. I was wondering if this HAT would work on an older Raspberry Pi 2 Model B (v1.1). It already has a LM75 thermometer mounted on the GPIO or is there some other way to attach it rather than through the GPIO (USB?) and still be able to script calls to send SMS (assuming through an API or AT commands). I too would like to use something like this on an existing Pi to make better use of it. Any advice would be appreciated.
Hi Bruce,
Welcome to the forum :slight_smile:
As far as pin compatibility goes that HAT should be fine with a RPi 2B.
You should be able to stack the LM75 thermometer on top of the 4G HAT since it has stacking GPIO headers fitted. You will just need to check there isn’t a collision between the GPIO pins in use by the 4G HAT. The pinout for the 4G HAT below shows the key pins you’ll need to keep free.
Thanks heaps for this. I will check the pins for the LM75 but I guess the Power and Ground would be good candidates for a collision. When stacked is it common for things to share power and ground?
Again thanks for your help
Hi Bruce,
That’s a great question, I simplified things a bit in my first answer.
You will want all devices to share a common ground connection, sharing a power rail is also fine provided the total power consumption of the devices is within what your power supply can output.
If you have devices that are using a communications bus like I2C or SPI, those pins can also be shared between devices so long as each device has a different address.
The big risk with stacking devices on a Raspberry Pi will be running out of power or having digital input or output pins that two devices are trying to control exclusively.
Thanks again.
Based on what I can see from the physical LM75. I think there will be a collision on Pins 7 & 9. 9 being a ground maybe ok. But 7 seems to be some type of Flight Mode toggle. According to your diagram it can be ‘enabled’ with a jumper so I am assuming it can be disabled without a Jumper. Which again with my limited knowledge would mean the pin wouldn’t carry any signal and thus could be used by the LM75 sitting on top of it? Or is that just pure rubbish from a novice?
cheers
This isn’t my board with a LM75 but it does match the position of the LM75 on my board.
lm75
Hi Bruce,
You won’t be able to use Pin 7 for another device without interfering with the operation of the 4G HAT.
There is some more info on how the HAT works on the manufacturer’s wiki page.
This graphic in particular explains what is going on. The Raspberry Pi is using D4 to indicate the status of Flightmode to the HAT. If the jumper is disconnected then the signal won’t get through to the HAT and the flight mode control will be disabled but that won’t leave the pin free for use by the LM75 since the Pi is still trying to use it to talk to the HAT
Thanks Trent so seems another Pi might be needed.
Really appreciate your time and help
Will this work with the Raspberry Pi Zero WH 2 model?
Does this product still work in Australia after the closure of the 3G network? If so, what are some alternatives?
Hi @Freddy190151,
This board should still have internet functionality over LTE and From the Product Wiki FAQ Voice over LTE or VoLTE can be enabled allowing phone calls to work.
The only part I can’t find information on is SMS over LTE.
It should work but I’m a bit less familiar with SMS.
Thanks @Aaron . Can confirm this product still works in my area for SMS at least.
Thank you for letting us know :slight_smile:
Hi.
Does it work with regular cellular carriers sim cards?
Or prepaid modem sim cards only?
HI @Alex286297,
Welcome to the forum, I believe that prepaid SIMs are most popular for these HATs. I’m not too sure why these are the popular option other than cost. If you’d like to try another SIM we’d love to hear your results.
Not much discussion here on the use of the HAT with Arduino, so here are a couple of observations:
I have the HAT working for outgoing and incoming SMS and HTTP post/get via serial access from an Arduino nano. The only issue I had was lack of a reliable externalised reset signal for last ditch recovery, and resorted to using a cheap buck converter with an enable facility for the board power and to cycle the power to it if necessary. . This isn’t a recommended option, but works very well and keeps the weather station that it’s installed in up very reliably.
There is an option to change the HAT external signal levels to 5V, but I chose to use a simple 10k/22k resistive divider on the Rx pin and it worked fine.
I’m using the unit on 4G via an Aldimobile SIM (Telstra network).
