I am only knew to Raspberry pi. I am going through the setup of the waveshare 4G hat and when trying to unzip the downloaded file, an error was produced saying it was unable to create the output directory. It looks like the files were unzipped correctly before the error was produced. Is there something else I needed to do first on the pi?
Hi @RoscoPico - welcome to the forums ![]()
For the best chance of getting a helpful response, it helps us a lot if you can provide as much information as possible eg. screenshots of your terminal commands and outputs.
My guess would be you may be operating in a filepath that requires sudo permission.
You could try re-executing the command as sudo
Thanks Michael. sudo worked. Much appreciated.
