Hi, I am wanting to buy female pins to suit the raspberry Pi’s GPIO pins and I’m not sure which ones I need to buy.
Female Crimp Pins for 0.1" Housings 100-Pack
or
Crimp Pins for Female Housing Pins(PH2.54)
Thanks in advance, Dean
or
Hi Dean, thanks for the question, they’re actually the same product, just using different measurements one is 0.1" and the other is 2.54mm which is the same size. That’s the standard size for most pin spacing so either will be fine. Just up to you with how many you’re after. The second one is definitely better value so I’d go for that.
