I’m looking at getting the WIZnet Pico 2 Ethernet board - but I need PoE. Are these two parts actually compatible?
Hey there, @Daniel207612,
My initial thought was that there would be some sort of weird compatibility issue, but no, they are absolutely compatible, the POE Power Module is designed to work with the Pico and the following WizNet boards:
So you should be good to go.
I thought as much myself, but Liam at core Electronics couldn’t confirm so suggested I double check here
No worries, I’ll pass on the tip and let him know.
