This is a placeholder topic for “PoE Ethernet/USB HUB HAT for Raspberry Pi Zero” comments.
The PoE/ETH/USB HUB HAT is a PoE (Power over Ethernet) USB HUB HAT designed for Raspberry Pi Zero. By using this small HAT and some proper 802.3af-compliant power sourcing equipments, it is possible to provide both network connection and power supply for your Raspberry Pi in only one Ethernet cable, along with 3x extended USB ports.
I am wondering if this is compatible with the Raspberry Pi Zero 2 W?
Hi Christopher, Welcome to the forum!
I’d say so! While Waveshare doesn’t explicitly say so on the product page, the test points that matter (5V, GND, D+, D-) haven’t moved between the Zero 1 and 2, so you should be fine:
Does the Raspberry PI Zero POE Hat (SKU: CE08227) work with Raspberry PI Zero 2W?
Hi Paul and welcome to the core electronics forum!
looking at the product page under compatibility it looks like the POE hat is compatible with the Raspberry PI Zero 2W.
As observed by James back in Feb 2022 the test points have not moved between the Zero 1 and 2
more info regarding specs and compatibility can be found on the product page:
Hey @Paul207148,
Looks like Bailey has figured this one out for you.
The final setup will look a little different than the product photos if you use a Pi Zero 2W but should work just the same.
Best of luck with your future projects!
