WT32-SC01 Plus - ESP32 dev board With 3.5 Inch LCD Touch Screen (SS104990762)
This is a placeholder topic for “WT32-SC01 Plus - ESP32 dev board With 3.5 Inch LCD Touch Screen” comments.
WT32-SC01 Plus is a development board for visual touch screen, the board is equipped with GUI platform firmware developed independently, support graphic…
WT32-SC01 plus dev board with 3.5" screen. Are the ESP32’s ADC pins exposed on this board? I can’t find anything about ADCs at all. Thanks.
Hi Ian,
Welcome to the forum!!
In short, they are exposed but to use them you’ll have to disable WiFi.
Since this devboard uses the base ESP32 module (not an S2, S3, C3 ect) ADC2 and WiFi share a connection so only one can be used at the same time.
You’ll be able to use a softI2C or SPI external ADC though! Analog to Digital - Breakouts & Modules Australia
Hi there,
Any information on the connectors used on the Extended I/O Interface? Seem to skip over this detail on the datasheet.
In fact, part numbers for all the connectors would be useful.
Carl.
The larger connectors are referenced as MX1.25-XP in the datasheet, whereby X is the count of pins. Eg, MX1.25-7P (more info on the last page on the datasheet).
