I am trying to learn how to use the XBee Wireless Kit. I can connect two XBee modules to a Windows 10 PC using the XBee Explorer USB, find them in XCTU and get them to send text to each other. However I cannot get the Arduino XBee shield to work. I am following the Sparkfun tutorial at https://learn.sparkfun.com/tutorials/xbee-shield-hookup-guide . I have soldered the stackable headers to the XBee shield and tested the connections with a multimeter - all good. But I cannot get the XBee to send text to the Arduino in the Communication Test.I am using the latest versions of XCTU and the Arduino IDE and am experienced with Arduino. The sketch, from the Sparkfun website, is:
XBee_Serial_Passthrough.ino
Set up a software serial port to pass data between an XBee Shield
and the serial monitor.
Hardware Hookup:
The XBee Shield makes all of the connections you'll need
between Arduino and XBee. If you have the shield make
sure the SWITCH IS IN THE "DLINE" POSITION. That will connect
the XBee's DOUT and DIN pins to Arduino pins 2 and 3.
// We'll use SoftwareSerial to communicate with the XBee:
#include <SoftwareSerial.h>
//For Atmega328P's
// XBee's DOUT (TX) is connected to pin 2 (Arduino's Software RX)
// XBee's DIN (RX) is connected to pin 3 (Arduino's Software TX)
SoftwareSerial XBee(2, 3); // RX, TX
//For Atmega2560, ATmega32U4, etc.
// XBee's DOUT (TX) is connected to pin 10 (Arduino's Software RX)
// XBee's DIN (RX) is connected to pin 11 (Arduino's Software TX)
//SoftwareSerial XBee(10, 11); // RX, TX
void setup()
// Set up both ports at 9600 baud. This value is most important
// for the XBee. Make sure the baud rate matches the config
// setting of your XBee.
XBee.begin(9600);
Serial.begin(9600);
void loop()
if (Serial.available())
{ // If data comes in from serial monitor, send it out to XBee
XBee.write(Serial.read());
if (XBee.available())
{ // If data comes in from XBee, send it out to serial monitor
Serial.write(XBee.read());
I have tried hard to get it to work, but need help.
