40-pin Raspberry Pi GPIO Breakout (CE04441)
This is a placeholder topic for “40-pin Raspberry Pi GPIO Breakout” comments.
If you’re after a quick and easy to way to connect external circuitry up to your Raspberry Pi, then look no further! This breakout board has a form factor perfect for connecting to breadboards using the included 40-pin ribbon cable.
re: 40-pin Raspberry Pi GPIO Breakout
Do you think you could use it in reverse?
For example do the pins align up to the Pico header?
Hi Craig,
Welcome to the forum!!
Unfortunately the pinout for the Pi and Pico are very different:
However you could definitely make a custom adapter and use the 40-pin cable.
PS: Rob is working on this super cool Pico stacking project here: Stackable Raspberry Pi Pico dev system - #6 by Rob110829
(And I think there was someone doing similar in the Core tags on Instagram)
If you tell us a bit more about your project we might be able to help!
Big changes to that lately, I’ll post an update soon.
Rob
