Hi, all
Some problem with my project:
Hardware:
CL5631BW - 3 Digit 7 Segment Display
CD4511BE - BCD Decoder
The BCDA inputs are wired with 680 Ohm Resistor and the outputs are wired with 680 Ohm Resistors to the 7 Segment correctly.
Problem:
All Numbers shown on the Display are inverted (All segments that should be illuminated are dark and vice versa).
I think the decoder is for Common Cathodes. Is it possible to change the mode for the decoder to Common Anode? Thank you in advance.
