Hi Just purchased a ADA997 soliniod to run my home built Rotary Drum filter. At present I run a 12 volt caravan water pump through my switch. Can I connect the soliniod directly to my 12 volt car battery through my switch or do I need a 12v 1 amp adapter. Thanks for your help.
Hi Roger,
Providing the solenoid has at least 350mA to draw, it will be fine to use directly with that 12V source.
Fantastic thanks for your help. Rodger
