Adafruit Pi TFT Resistive Touch Screens - 2.2", 2.4", and 2.8"
Hi All,
We just had a customer with one of Adafruit’s 2.4" Touchscreens they couldn’t get working despite following the guides for a Pi 4. The HDMI worked flawlessly, but the touchscreen was a no go.
Adafruit’s last known good image no longer works, but the answer was buried in Adafruit’s forums:
We’ll update our product page and get in touch with Adafruit to get them to update their guide!
To get it up and running, here are the steps we took:
  1. Do a clean install of the latest Raspberry Pi OS and update everything.
  2. Download the relevant pitft file from here: https://github.com/raspberrypi/linux/blob/rpi-5.4.y/arch/arm/boot/dts/overlays/pitft28-resistive-overlay.dts
  3. Edit this file with your favourite text editor and add spi-cpha; ​ to the relevant section:
  4. Copy this modified file to /boot/overlays using:
    sudo mv <file location>/pitft28-resistive-overlay.dts /boot/overlays/
  5. Follow Adafruit’s Easy Install process as normal: https://learn.adafruit.com/adafruit-pitft-28-inch-resistive-touchscreen-display-raspberry-pi/easy-install-2
    cd ~
    sudo pip3 install --upgrade adafruit-python-shell click==7.0
    sudo apt-get install -y git
    git clone https://github.com/adafruit/Raspberry-Pi-Installer-Scripts.git
    cd Raspberry-Pi-Installer-Scripts
    sudo python3 adafruit-pitft.py --display=28r --rotation=90 --install-type=console
  6. Finally, compile the modified overlay file and reboot:
    sudo dtc -@ -I dts -O dtb -o /boot/overlays/pitft28-resistive.dtbo pitft28-resistive-overlay.dts
    ​sudo reboot
If you follow these steps, you should have a working Pi TFT Hat!
