Hey everybody,
I’m trying to run my Adafruit soundboard using this code I copy and pasted from the Adafruit website:
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 7
#define SFX_RX 12
// Connect to the RST pin on the Sound Board
#define SFX_RST 4
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
// pass the software serial to Adafruit_soundboard, the second
// argument is the debug port (not used really) and the third
// arg is the reset pin
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
void setup() {
Serial.begin(115200);
Serial.println("Adafruit Sound Board!");
// softwareserial at 9600 baud
ss.begin(9600);
if (!sfx.reset()) {
Serial.println("Not found");
while (1);
Serial.println("SFX board found");
void loop() {
flushInput();
Serial.println(F("What would you like to do?"));
Serial.println(F("[r] - reset"));
Serial.println(F("[+] - Vol +"));
Serial.println(F("[-] - Vol -"));
Serial.println(F("[L] - List files"));
Serial.println(F("[P] - play by file name"));
Serial.println(F("[#] - play by file number"));
Serial.println(F("[=] - pause playing"));
Serial.println(F("[>] - unpause playing"));
Serial.println(F("[q] - stop playing"));
Serial.println(F("[t] - playtime status"));
Serial.println(F("> "));
while (!Serial.available());
char cmd = Serial.read();
flushInput();
switch (cmd) {
case 'r': {
if (!sfx.reset()) {
Serial.println("Reset failed");
break;
case 'L': {
uint8_t files = sfx.listFiles();
Serial.println("File Listing");
Serial.println("========================");
Serial.println();
Serial.print("Found "); Serial.print(files); Serial.println(" Files");
for (uint8_t f=0; f<files; f++) {
Serial.print(f);
Serial.print("\tname: "); Serial.print(sfx.fileName(f));
Serial.print("\tsize: "); Serial.println(sfx.fileSize(f));
break;
case '#': {
Serial.print("Enter track #");
uint8_t n = readnumber();
Serial.print("\nPlaying track #"); Serial.println(n);
if (! sfx.playTrack((uint8_t)n) ) {
Serial.println("Failed to play track?");
break;
case 'P': {
Serial.print("Enter track name (full 12 character name!) >");
char name[20];
readline(name, 20);
Serial.print("\nPlaying track \""); Serial.print(name); Serial.print("\"");
if (! sfx.playTrack(name) ) {
break;
case '+': {
Serial.println("Vol up...");
uint16_t v;
if (! (v = sfx.volUp()) ) {
Serial.println("Failed to adjust");
} else {
Serial.print("Volume: "); Serial.println(v);
break;
case '-': {
Serial.println("Vol down...");
uint16_t v;
if (! (v=sfx.volDown()) ) {
} else {
Serial.println(v);
break;
case '=': {
Serial.println("Pausing...");
if (! sfx.pause() ) Serial.println("Failed to pause");
break;
case '>': {
Serial.println("Unpausing...");
if (! sfx.unpause() ) Serial.println("Failed to unpause");
break;
case 'q': {
Serial.println("Stopping...");
if (! sfx.stop() ) Serial.println("Failed to stop");
break;
case 't': {
Serial.print("Track time: ");
uint32_t current, total;
if (! sfx.trackTime(¤t, &total) ) Serial.println("Failed to query");
Serial.print(current); Serial.println(" seconds");
break;
case 's': {
Serial.print("Track size (bytes remaining/total): ");
uint32_t remain, total;
if (! sfx.trackSize(&remain, &total) )
Serial.print(remain); Serial.print("/"); Serial.println(total);
break;
/************************ MENU HELPERS ***************************/
void flushInput() {
// Read all available serial input to flush pending data.
uint16_t timeoutloop = 0;
while (timeoutloop++ < 40) {
while(ss.available()) {
ss.read();
timeoutloop = 0; // If char was received reset the timer
delay(1);
char readBlocking() {
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff) {
uint16_t buffidx = 0;
while (true) {
if (buffidx > maxbuff) {
break;
if (Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) { // the first 0x0A is ignored
continue;
buff[buffidx] = 0; // null term
return buffidx;
buff[buffidx] = c;
buffidx++;
return buffidx;
However, when I run this exact code, It says my soundboard can’t be found:
Can you help me isolate the issue? I’m not sure whether this issue is a coding issue, soldering issue (I soldered the RX TX and RST pins), or something else?
Do you have any guidance on how to troubleshoot and find out what the exact problem is?
Here’s my wiring for reference:
Thank you everybody!
