I bought the Adeept Ultimate kit For Arduino UNO and am at lesson 2 (Active buzzer) in the supplied tutorial.
Wiring as per the instructions, it does not work. I have copied someone else’s unanswered question on this for ease. I would really like to know why this won’t work.
Newbie here. I purchased the Adeept Ultimate Arduino Kit and I’m following the tutorial howver I’ve struck a problem with lesson 2 - active buzzer . It doesn’t work properly . This is the scematic:
I’ve totally rebuilt this a dozen times and even bought extra parts to swap out in case components were faulty.The result are contant, the buzzer clicks but emits no audio. However the buzzer tested as a stand alone works just fine. Here’s the rub:
- If I wire it exactly as described, then apply power OR upload the sketch, it only clicks - always.
- If I then remove the 5v power jumper wire from the breadboard and reinsert it, it will only click OR buzz for a second then begin clicking.
- If I do exactly as above but keep inserting and removing the power, it will eventually work for a few seconds and then start clicking again.
Note I have tried different leads, different components and combinations of (including a different Uno), different breadboards - the results are constant. Any ideas please?
