This is a placeholder topic for “Aluminium Heatsink for Raspberry Pi Zero Series” comments.
Dedicated Aluminum Heatsink For Raspberry Pi Zero Series, Zero / Zero 2 W…
Read moreThis is a placeholder topic for “Aluminium Heatsink for Raspberry Pi Zero Series” comments.
Read moreI found that the heat pad on the smaller chip was too tick for the main CPU heat pad to contact the heatsink. Using a sharp blade, skimming the top off the smaller chip heat pad made both pads contact the heatsink.
Don’t let this put you off buying, just beware to check the clearance and trim if necessary.
Hey Hotswapster,
Welcome to the forums!
Thanks for that advice, we will have a look into it so that we can provide that information on our product page.
Blayden
