This is a placeholder topic for “Anderson Connector With Fuse and Lug” comments.
Make sure you connect your battery safely!
Read moreThis is a placeholder topic for “Anderson Connector With Fuse and Lug” comments.
Read moreHow long are the leads?
Hi @Sam29143
The cable on this item would be 220mm from the housing of the anderson plug to the cover crimp connection on the ring terminal
