This is a placeholder topic for “Arducam 64MP Pi Hawk-eye Camera Module” comments.
The same form factor as the official Raspberry Pi Cameras with 64 MP!
Read moreThis is a placeholder topic for “Arducam 64MP Pi Hawk-eye Camera Module” comments.
Read morewill the Arducam 64MP Pi Hawk-eye Camera Module.
Note: 64MP is compatible with the Raspberry Pi 4 and CM4. Other boards (Pi 2/3/CM3/Zero) will run at 16MP.
if so what is the minimum memory requirement
Hi there, @daniel167157, and welcome to the forum. Glad to have you here.
Unfortunately, when I’ve tried to look up the specs for this module, they haven’t included a minimum memory requirement.
Presumably this is because the device was designed specifically for the Pi series which has known RAM specs for each model. It must have been easier to specify which devices it worked with rather than defining minimum memory requirements.
thanks jane,
I’ll see if i can get a response from the manufacturer, not always an easy task.
Kind regards
Daniel Smith
