I Have Just purchased the Arduino nano v.3 and Wanted to try for the first time to make a small little test project where it tells me the temperature and humidity using the DHT-11 Temperature and humidity sensor. I Verified the code, It says Compiling Sketch and it works, When i Upload it, it gives me these error messages. What Do they mean?
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed uploading: uploading error: exit status 1
I then changed the ports to try on the Software and now it says this.
Sketch uses 4404 bytes (14%) of program storage space. Maximum is 30720 bytes.
Global variables use 293 bytes (14%) of dynamic memory, leaving 1755 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can’t open device “/dev/cu.wlan-debug”: Resource busy
