Hey,
I’m attempting to upload code to my Arduino Nano but I’m receiving an error: avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4b
I’ve tried two computers, two Arduinos and two different cables.
Has anyone else run into this issue or does anyone know of a fix?
This is the Arduino’s that I bought:
@Rooppoor212784 is spot on here, it has a FT232RL for USB-to-Serial comms on the board, which for most OS will require some additional drivers to be installed.
Depending on your OS, it may be installed already or automatically, but otherwise, per the communication section on this datasheet:
You’ll need to install the appropriate FTDI drivers either from the Arduino IDE if they’re available for your OS from there, or from ftdichip.com directly (linked below for you):
Generally it is older product that has the older bootloader, but which version you get also seems to depend on the availability of the USB chips at the time they are made. But of course, you never know the age of the stock you are buying.
