Hope someone can assist with my issue on Argon One V2 fan script. When I try to install using the script (curl https://download.argon40.com/argon1.sh | bash), I’m returned with a Could not resolve host: download.argon40.com error. I’m definitely connected to the internet as I’m using this Pi to run my Plex.
While you definitely have LAN connectivity (I can see you’re SSHing in), either your package manager sources or DNS might be playing up. Pinging www.google.com or similar should reveal DNS issues, and hitting sudo apt updateshould sort out sources (unless the Pimoroni script calls for more, but it should handle adding them itself).
I’d also be interested to see your ifconfig info, and cat /etc/resolv.conf to see what your DNS is doing.
right click link above and choose “open link in new tab”…download link should prompt up…i tried the link on a win box …if need be save file to usb stick and take to your linux machine copy file to a dir of your choice and follow below…
chmod 755 argon1.sh
hit enter
then next
run the file from its present location ./argon1.sh and the installer will run …
once done…goo to the “etc” dir and find the argononeconfofd file its someting like that i think you will find it… its at the start of the listings in the etc dir
and edit the values
give that a try…
my settings i manually have done as per this page basically…cpu temp`s are on the left and fan speeds %tages are on the right you can play with the values to meet your needs…
32=40
35=50
37=60
39=80
40=100
42=100
45=100
47=100
49=100
53=100
55=100
60=100
delete the old entry`s in the file and
copy past the above values into the file if need be adjust as required…enjoy…
save the file and reboot
