I have 3 of these controllers that I’m trying to use for a project. I’m having major issues trying to get them to consistently connect and stay connected. I’m currently using my Ubuntu workstation (not an rPi) as a development environment.
$ sudo hciconfig
[sudo] password for james:
hci0: Type: BR/EDR Bus: USB
BD Address: 00:1A:7D:DA:71:13 ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING PSCAN
RX bytes:676 acl:0 sco:0 events:47 errors:0
TX bytes:2463 acl:0 sco:0 commands:47 errors:0
$ sudo bluetoothctl
[NEW] Controller 00:1A:7D:DA:71:13 james-ws-ubuntu [default]
[NEW] Device E4:17:D8:7B:0F:75 8Bitdo SN30 GamePad
[NEW] Device E4:17:D8:56:0B:7B 8Bitdo SN30 GamePad
[NEW] Device E4:17:D8:04:0B:7B 8Bitdo SN30 GamePad
[bluetooth]# paired-devices
[bluetooth]# scan on
Discovery started
At this point I press Start to power on each of the three controllers
[CHG] Device E4:17:D8:04:0B:7B RSSI: -53
[CHG] Device E4:17:D8:56:0B:7B RSSI: -49
[bluetooth]# connect E4:17:D8:04:0B:7B
Attempting to connect to E4:17:D8:04:0B:7B
[CHG] Device E4:17:D8:04:0B:7B Connected: yes
Failed to connect: org.bluez.Error.Failed
[CHG] Device E4:17:D8:04:0B:7B Connected: no
[bluetooth]# connect E4:17:D8:56:0B:7B
Attempting to connect to E4:17:D8:56:0B:7B
[CHG] Device E4:17:D8:56:0B:7B Connected: yes
[CHG] Device E4:17:D8:56:0B:7B Connected: no
As you can see, only two of the three controllers are even detected in the scan and neither of those two are able to be connected.
Trying them one at a time:
$ sudo bluetoothctl
Discovery started
Pressed Start on one controller only
…nothing. No signal.
Putting that controller back into pairing mode by holding Start + B then holding Select:
bluetooth]# scan on
Discovery started
[CHG] Device E4:17:D8:56:0B:7B RSSI: -57
[CHG] Device E4:17:D8:56:0B:7B RSSI: -47
[bluetooth]# pair E4:17:D8:56:0B:7B
Attempting to pair with E4:17:D8:56:0B:7B
Failed to pair: org.bluez.Error.AlreadyExists
At that time, this is logged to syslog:
Sep 12 08:13:29 james-ws-ubuntu bluetoothd[4918]: Can't get HIDP connection info
Sep 12 08:13:32 james-ws-ubuntu bluetoothd[4918]: connect error: Invalid exchange (52)
Tried explicitly trusting it and pressing Start on the controller to power it on - got a signal this time but - still no good, same error logged to syslog:
[bluetooth]# trust E4:17:D8:56:0B:7B
[CHG] Device E4:17:D8:56:0B:7B Trusted: yes
Changing E4:17:D8:56:0B:7B trust succeeded
[CHG] Device E4:17:D8:56:0B:7B LegacyPairing: yes
[CHG] Device E4:17:D8:56:0B:7B RSSI: -81
[CHG] Device E4:17:D8:56:0B:7B LegacyPairing: no
[bluetooth]# info E4:17:D8:56:0B:7B
Name: 8Bitdo SN30 GamePad
Alias: 8Bitdo SN30 GamePad
Class: 0x002508
Icon: input-gaming
Paired: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Human Interface Device... (00001124-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
Modalias: usb:v2DC8p2862d0100
RSSI: -47
Any ideas?
