Coin Acceptor - Programmable (6 coin types) (COM-11636)
This is a placeholder topic for “Coin Acceptor - Programmable (6 coin types)” comments.
Are you trying to make a quick dime from electronics? Why limit yourself to dimes? This coin acceptor will take up to 6 different kinds of coin! Whether you’re building your own arcade cabinet or just charging admission to your house, this programmable coin acceptor makes it easy to monetize your next project.
Hi
Just seeing if this coin mechanism, SKU.COM-11636, will work with $2 coins?
And if the mechanism has to be programmed for particular coins?
Simon
Hi Simon,
Yes, it will work with $2 coins. You program them by feeding it samples of the coins you want it to recognise, and then it outputs a signal you can hook into your projects when a coin is inserted.
Here’s the direct link to the guide for you:
Thanks Oliver
Just wanted to make sure before I purchased it.
Thanks again.
Simon
No worries, just let us know if you have any other queries :slight_smile:
This might sound silly but relatively new at This coin mech repair, wondering once you program the coins how do you get the machine or mech to recognise what equals a credit for gameplay so if it is $1 a play and you put 5 20c etc or a single coin so a credit is registered
It’ll depend on your machine. You might need a microcontroller in the middle - like an arduino - to covert whatever the coin acceptor outputs to something the machine recognises.
Thanks for the reply So does that mean the machine is already preprogrammed to a certain denomination in order to register a credit ? It’s second hand machine btw
Nah that’s: I don’t know - you’ll have to test it :wink:
